Arcam Solo Movie 5.1 Kef & BD80 v Bose
Hi all.
I'm about to replace my all with a one box. and need some insight and opinions.
I have looked at the Bose Lifestyle 48, The Arcam Solo Movie 5.1 and Kef KHT3005se.
Neither of these has blue ray so was going to get a Panasonic BD80 for that as an add on.
I suppose you can work out the money I want to spend by the above list. Any other recommendations?
I'm running out of room so size does matter. I will want a least 2 zones.
I'm also concious that these items may be replaced by the manufacturers soon as they have been around for a while???.Do I wait a while? I'm tired of waiting though
What do you think?
Selby
There is no HD audio decoding in the products you have chosen so a good alternative will be the Marantz NR1501 slimline amp with a matching BD5004 or BD7004. Put this with the KEFs and you will be all set.
Thanks for that they look good.
Thats down to 2 boxes, Can I get all that in 1 box??
Selby
There are all in one bluray systems but they tend to have their own speakers. If you are looking for better sound quality then the Marantz combination is the only one I can think of .
