Arcam CD37 DAC or Pioneer SC-LX83 DAC?
Not sure where to post this but was just looking for comments around the best setup of the Arcam CD37 and Pioneer SC-LX83 reciever.
Setup one: Use the Arcam CD37 Wolfson 8741 DAC through its analog connection to the Pioneer
or
Setup Two: Use the optical toss out of the Arcam CD37 to the Pioneer DAC (only info on the DAC I could find was that it is 32bit)
So optical toss or analog interconnects. I only have some crappy analog interconnects at the moment but that is a whole different debate.
Total setup is:
Pioneer SC-LX83
Arcam FMJ CD37
Monitor Audio GX100
What do people think?
nlanks
23
Traditional (ie my) thinking would be the Cd player DAC would be better.
This though sounds like the ideal opportunity for you to do a test! Hook both up (you can get an optical for £5 from thatcable), put a blind fold on, play some music and get someone to switch between the inputs not telling you which is which.
Stick with the one you like the best :)
ID.
207
From what I can see the Pioneer uses a 32 bit Asahi Kasei DAC chip. It is a good chip, but there is much more to digital-analogue conversion than the chip itself, so definitely give them both a go and see which you prefer.
The Asahi Kasei chip seems to be the favoured chip of many Japanese manufacturers at the moment and it is popping up everywhere, but I haven't compared many products using it. I know Esoteric for one are very keen on it and using it for all their latest equipment.
Overdose
279
or
Total setup is:
Pioneer SC-LX83
Arcam FMJ CD37
Monitor Audio GX100
I think that you should try for yourself.
