Hi Iceman.
Receive my two lunar5 cables a few days ago. The lunar5 is designed to replace the snaic type
cable (power + signal) between nac and power supply (hi-cap). I required two for my set up
nac282 dual teddy-cap.
First impressions in order. 1; Deeper controlled bass 2; Better wider soundstage 3; More detail, especially
at low frequencies. I'm sure there will be further improvements as the cables burn in.
It took a huge leap of faith to buy these cables as like you, I had only read reports.
I believe you can return cables for full refund (less postage) I certainly won't be.
