If you read their webpage it's $28 delivery.CS85 said:Hi all,
I'm considering getting a groovetracer reference sub platter and I was hoping to get an idea of the fees involved in getting one delivered to the UK. Are there any members that have one and can tell me roughly what they had to pay?
Kind Regards,
Chris
Depending on the actual price the exporter declares to customs it will be +20% VAT on total amount + Duty if it exceeds £135 in value + delivery agent admin charge. An online tax and duty calculator will give you a good indication of HMRC charges.CS85 said:Hi all,
Kind Regards,
Chris
Yes £300 does seem excessive for a RP3. I would give the Tangospinner a go, should be about £130.Al ears said:If this is the case the OP would clearly be better off buying a new turntable.
Possibly so but even then you have to ask whether that upgrade in itself is going to raise the stakes enough to outperform a new turntable. Now if he was upgrading the cartridge it might be a different matter. ;-)BigH said:Yes £300 does seem excessive for a RP3. I would give the Tangospinner a go, should be about £130.Al ears said:If this is the case the OP would clearly be better off buying a new turntable.
