Anyone have or heard Sonos Faber Cremona Auditor Loudspeakers
michael hoy
840
325
19,270
I have a chance to purchase some of these speakers, but cannot audition them.
1. Are they any good.
2. will the match with a Cyrus 8 XPd QX amp
3. Cambridge Audio Azure 840A
Or are there better choices for the above amps
Hi, never heard the italian make. Saw that Sonus won a group test, though.
I heard them with a tube amp and with a Lavardin IS reference and found them to be very good and also look very nice. I liked them a lot...not sure how they would match with your speakers though...
Anyway at this level of price I would not want to buy anything without audition...I am sure you have shops around you stocking Sonus Faber speakers...
Yes of course I do have the Sonus Faber Cremona's, but not the auditon m's. I have had them for just over a year now. I got my pair second hand. never regrated it for one moment. I have the floor standers. OF course there is the the Cremona m's which are the small ones. I bought my pair with a unison amp. But just out of curiuosity decided to try them with my Marantz Sr6003 & was very surprise with the musicality i was getting.. The marantz amp has seen been in place.
If you can buy Sonus faber speakers i Would not hesitate at all. I have a recording studio & have listened to lot of speakers, but the faber's just sound so good to my ears. Then again it's a matter of taste & how you like your music to sound.
I would say the sonus faber's sound open, Smooth & rich sounding. The Audition m's basically have the same sound as the Cremona floor standings, But not as opened & not as big a sound stage.
If you can audtion pls do so before buying.
Good luck.
