Anybody got a NAD D3045
Witterings
868
581
11,770
Interested to hear from anyone who's got a NAD D 3045 or heard / compared one at a Demo, thinking about getting one and hoping it'd be an upgrade from my Denon M39 Dab which is moving to another room.
Have heard some comments in the past though saying they're not quite so "musical" as the 3020.
Hi, I have heard some 10 -12years ago Nad D3020. It was presented as "digital breakthrough" but I was not impressed at all. I am sure "classic" amp like Rega Brio sounds better, has more emotions, energy and it is speaking to me. I have Brio mk6 at home some 6 years, very happy with him. If you need digital, than new Arcam A5+ or Audiolab 6000mk2 are better options than this old Nad D3045 for sure. If you like sound signature of your Denon M39Dab, than I recommend to look on some Marantz or Denon with streaming and DAC, like Marantz N7000. Today possible to buy for some 699£. This is very good grown up amplifier, class leader. My friend use it with Monitor Audio Bronze 500 speakers and Project turntable in quite bug room. It sounds very good. BR.
If the Rega or Cyrus One had 12v trigger in, they'd be my 1st choice as I could set up it as one button pre-set for the Mrs to turn the radio on but unfortunately they don't ... I also have a size limitation of 24cm x 40cm, currently the Denon is under 24cm wide so the shelf is running front to back in a corner but I could rotate it if it was wider but would need to stay within the same max sizes unfortunately.
I see you have a Wiim Pro and Bluesound Nano. Would something from their respective stables suit, given you'd then potentially get streaming and amps in one box?
I realise a bit of homework might be necessary spec-wise, but they’d probably fit. I’ve not had any experience with the D3045 but vaguely recall it was well received.
I have looked at the WiiM and Bluesound offerings (Ultra Amp, Vibelink, Powernode) and discounted for various reasons. Whilst I was doing an upgrade was hoping to go more "HiFi" orientated if that makes sense and may upgrade the speakers at some stage as well.
I was guessing that as the little NADs get so much positive feedback that hey might be step n that direction.
Reactions: nopiano
It certainly gets a pretty good technical review over at ASR. I can’t see it listed by Sevenoaks so I wonder if it has been discontinued?
Yes, I think it has been discontinued so was probably looking at 2nd hand.
Since replying to your last post I've spent the whole time querying AI and I think I'm going to get a 2nd hand Cyrus and just leave it switched on a lot of the time, cost's about £30 a year more than some something that goes into standby.
The others I was comparing it to were a Nord Value-Line MP NC252 and a Rega Brio R, seems like my music taste and listening levels it may be the best all round choice according to chatgpt.
Reactions: nopiano
