any multiregion blu ray players
i have just seen the sony bdp 550 blu ray player advertised on ebay as multiregion player,, that will play blu ray a +b and dvd region 123456 does this mean it will play american coded blu ray discs-- or just dvd part of the player as multiregion player-- -all this is a bit to complicated for me to understand i think i have read somewhere you cant get multiregion on blu ray players..
Andrew Everard
1,878
If it can play regions A+B on Blu-ray, then yes it will play US-sourced discs.
But I am pretty confident this isn't a Sony-authorised modification, so you take your chances if it won't play some discs, or if anything else goes wrong, as the modification will have invalidated the standard warranty.
And frankly I'd be wary of accepting an aftermarket warranty from a seller on a site such as that, especially as the seller is based in the States and you'd presumably have to send the machine back there for any service.
Oh, and £876???
D.J.KRIME
160
They update stock daily smartiepants
lol. I know they have stock issues due to Panasonic new models but they are a good company to deal with.
skularatna
87
RGB direct do a multiregion DMP-BD35. I think it's their own modification but its priced at £218.00
http://www.rgbdirect.co.uk/ProductDetails.asp?SKUNumber=107047&Model=DMPBD35EGK
Bear in mind that is multiregion for the DVD side of things as opposed to multiregion Blu-ray.
Garth Man
156
I don't get it, Toshiba cracked it with HD-DVD, specs, extras, DVD copies bundled with them and were allregion free. And the companies choose the overpriced, lower spec machine at the time (Bluray),
Sorry in answer to the question, you can get a lot of Bluray discs from America that are region free at
http://www.movietyme.com/catalog/default.php?cPath=210&osCsid=6e59f2003b76c46ad8594c4883d0900f
Some are overpriced but you can see which are region free then buy them from Playusa or other companies
