idc
Tarquinh:
Can I suggest you head down to your local dealer, borrow a range of cables ranging from £10 to £200 and settle down for a weekend's listening. Include your current cables in that, and bear in mind you may have to tweak the volume here and there.
Saved me a lot of money.
Have the cables swapped about for you so you do not know which is which. Make sure the volume is equalised between cables, as different cables can result in a different volume. That is important as it is the only actual difference a cable can make to the sound. Anything else is interfered with by our other senses, from a brand preference to the look of the cable to its cost.
