Andrew / Clare - Help!!!
Hi
I am having trouble with the Samsung LE26A457 picture setting despite using the THX optimiser setup. The colours just seem a bit dull and generally the picture is quite dark. Could you kindly post what the picture settings should be for this TV? Thank you in advance
Try These,
mode Standard
Backlight 8
Contrast 82
Brigthness 46
Sharpness 52
Colour 46
Tint 50
Detailed Settings
Black Adjust High
Dynamic contrast Low
Gamma 1
Colour space Auto
Flesh Tone -2
Edge Enhancement On
Picture Options Cool 2
Digital NR Auto
Hope that helps you
good luck
Clare Newsome
1,657
Have you tried the ones above?
Without the set in front of me (and even if I did) I can't help much beyond that, i'm afraid, as everyone's room/lighting is different.
You've done the right thing by running THX - now take a tweak yourself with contrast/colour/brightnesss until you get a personalised fit for your room.
I tried JJ's settings and unfortunatley they did not work for me
Clare Newsome
1,657
...which shows exactly what I mean about everyone's set up being different.
I'd go back and re-run THX Optimiser (with the glasses, if you can get hold of a pair) and then customise the results by hand to suit.
The contrast setting proved rather impossible to set using the THX as turning the contrast up or down didn't show the different shades of white as it should do - just one shade
jase fox
212
Cube, set your contrast to around 3 quarters, brightness just abit below half way & colour about a quarter up.
The THX optimizer sets the brightness way to low IMO & the contrast does only show 1 shade thats why i suggest setting your contrast as ive stated, if you set em to this itll be a better guiedline for you.
