Analogue to Digital Convertor
El Hefe
259
10
18,895
Hi all, Is there such gadget available to convert analogue source such as tape decks to digital format (say mp3)? If yes, anyone has details of it and where it can be purchased?
AlmaataKZ
295
one option is to get a (second hand) CD recorder. the yave analog inputs and give you a CDR which you can then rip into mp3 or another format.
http://www.music-instruments.co.uk/tascam-cdr4u-p-4330.html
http://www.google.co.uk/products?q=cd+recorder&hl=en
ebay?
There are of cause also standolone AD converters. Both cheap and expensive.
http://www.benchmarkmedia.com/adc/adc1-usb
http://www.google.co.uk/products?q=analog+to+digital+converter&hl=en
What are you thinking of doing? I think I remember there was an LP player with USB out or somth liek that.
PC soundcards also probably have analog inputs and can probably do h-rez (24/96 or 192) conversion?
El Hefe
259
10
18,895
Thanks all for the reply. After googling and a bit of research, I opted for NAD PP3 Phono Pre amp but with line in and usb output to PC. Did my first conversion from DIO Locked Up The Wolves cassette to the PC. The sottware is quite easy to use except that I need to split the tracks manually.
The conversion option includes mp3@48kHz, FLAC or WAV.
John Duncan
2,031
15
19,695
I am. It may not be the ultimate in analogue to digital conversion, but for your purposes that and Audacity would be perfectly fine (unless your source is a Nakamichi Dragon...). There are software packages out there that will split your tracks automatically for you as well.
All a bit late now though obv
John Duncan
2,031
15
19,695
Because unless the source is that good the quality of Analogue-to-Digital conversion in your PC is the least of your worries.
I'd buy a subscription to Spotify instead...
El Hefe
259
10
18,895
Aaaahhh yes the cassette conversion just improved the sound by minimising the background hissing sound. However, converting from MD is much better.
As JD points out, the sound quality of analogue sources are seldom (if ever) what we're used to in this digital age. I've made quite a few digital copies of old analogue stuff, and I've always found that buying the music from iTunes (ACC) gives a far superior sound quality.
Not because the digital equipment weren't good enough, but because analogue sound reproduction is marred by noise, speed instability and other kinds of distortion.
You might make yourself deaf to this when listening to your old analogue gear -- but you'll sure hear it when you get the recordings into a computer and can compare it directly with digital originals...
If you've got unique material that's not available in digital formats, the USB phono boxes with line in from NAD or Pro-Ject will be fine. So will an inexpensive USB sound card, or even a decent built-in sound card.
El Hefe
259
10
18,895
Yes i totally agree. The conversion I made so far cannot compete a remastered copy in CD format. But as you pointed out, its the unique albums that I am preserving. Some are recording of my jammin sessions from 20 years ago :)
El Hefe
259
10
18,895
Oooopppss first hurdle encountered. The VinylStudio software allows to split the tracks after conversion. However, I cant get it to work (I am sure I am doing something wrong). It can physically scan for track breaks between songs but I cant seem to 'finalise' or 'execute' the split. Mainly because I cant find the any 'Execute' icon/button.
Any clues?
ASK THE COMMUNITY
