stevebrock
- Nov 13, 2009
- 183
- 1
- 0
Freddy58 said:Hi there my fellow old timer(s) 🙂
I'm probably being thick (won't be the first time :doh: ), but how do I go about deciding on a pair of speakers? From what you say the chances are that a speaker that doesn't sound that great in the shop might sound great in my room? What if I hear a speaker that I like the sound of at the shop but can't tell what it's like at home with no other components to drive them until I buy them? What if, once I buy the other components but then don't like the sound? How will I know if it's the speakers or the other components? This is why I'm very tempted to build my own speakers based on my old Kefs, because they sounded good in my two previous homes. It's all very confusing!
Cheers...Freddy
part of the seceret is to bild up rapport with your local hif dealer if you have one, its a very timne consuming affair - but is worth to avoid making expensive mistakes.
However in reality sometimes it isnt possible to do this so its all a compromise.
Most decent hifi dealers will let you borrow their demo speakers for you to try at home
