Goldring back in the turntable arena - GR3
record_spot
754
654
19,770
About 15 years ago, Goldring had released the GR1 and GR2 turntables, manufactured for Goldring by Rega, they were well reviewed. I remember the GR2 looked a pretty decent option as it came bundled with a decent cartridge and I think the RB300 arm of the day.
Well, they're back in town with a new deck, still made by Rega it seems, and they no doubt burnt the midnight oil coming up with the new name - the GR3!
Comes bundled with Goldring's own E3 cartridge, the blurb doesn't reference Rega directly, but it looks the diddly spit of your typical Rega tonearm and deck and an onboard phono preamp. £699.
Details below:-
Reactions: Revolutions
Details below:-
It's still a Rega with a different cartridge that costs too much.
That looks closer to a P1 than a P3. If I'm correct, it's overpriced. There's a cavern between even the P2 and P3. After that, diminishing returns set in, at least until you get to the P8, but I'd be looking at a rebuilt LP12 were I to find myself in that territory.
Perhaps a Technics DD.
To be honest I found the LP12 to be on of the most finicky and over rated decks of the time, and moreso now, as much relied on you buying expensive "upgrades" to even bring it up to an acceptable level.
One deck I have never lusted after.
Yes, that would put me off an LP12. I don't want hi-fi there's a constant temptation to mess with, I'm bad enough as it is!
I did once have a 1210 Mk5, and should have kept it. It probably had more potential than the P3 I have now, good though that is.
Somebody else had a rant last year about another Rega clone/derivative, along similar lines!
Well, this blew up!
First off, oh dear Goldring...what *have* you done! The GR2 I recalled being a decent offering with a good cartridge.
The Exposure review from Paul Rigby I recall! He didn't hold back.
Orange have a deck too which I think might be a Project rebadge? They're a little guarded on this and reviews are few.
It’s fascinating that Pro-ject make far and away the most turntables anywhere in the world, and that includes custom versions for the like of Musical Fidelity (amongst others), and their own special division EAT.
I presume Technics may be next, but Rega must be quite large volumes too. And there are various OEM makes too, is Hanpin one?
%2Fmethode%2Ftimes%2Fprodmigration%2Fweb%2Fbin%2F676e30ef-9334-352a-a772-85082f86265f.jpg
Reactions: matthewpianist
No1 Project is a Titan with about 50% of the global market $300+ TTs
Project build turntables with 99% of components made in house
No2 Technics has about 15% of the global market $300+ TTs
Technics build turntables with 99% of components made in house
No3 Yahorng produce several hundred thousand turntables
No4 Hanpin produce several hundred thousand turntables
Yahorng/Hanpin are both $100+ million turnover in under $300 turntables
No5 Rega has about 10% of the global market in over $300+
Rega assemble turntables from components from 900 external suppliers
