Hi, I'm looking to upgrade my current Cambridge Audio Azur 340a amp. I've got some ideas and will be auditioning in a week or two but my current list is a bit too long and I'd really like to narrow it down, to save time and confusion. My budget is around the £500-600 mark but potentially flexible up to a grand at a push if I'd really hear a marked improvement in soundstage etc. I listen to a range of music but mainly rock, soul, funk, jazz and ambient/chilled out electronica. I also use the amp for watching DVDs & some TV. I dont generally play music loud so looking for good presentation at lower volumes, as neutral as possible, but overall probably prefer a rich/warm sound over clinical. Room size is about 3.5x4.5m, if that helps.
Current set up: Cambridge Audio Azur 340A, CA Azur 340C, Rega RP1 (& Rega Fono Mini) & Dali Zensor 5s
Current shortlist: Marantz PM6005 (not sure how much of an improvement this would be); NAD C 326BEE or 356BEE DAC; Rotel RA11 or RA12; Rega Brio-R; Arcam FMJ A19 (widely regarded but 2 people on this forum have said it doesn't pair well with the Dali's); Roksan Kandy k2 (I've been told this may be a bit much for the Dali's); Rega Elex-R; Naim Nait 5si; Musical Fidelity M3si.
I would not rule out higher spec'd Cambridge Audio, Marantz, Pioneer, Denon etc.
In terms of auditioning, the two shops I'm planning on visiting dont sell Dali speakers but I've been told that B&W should be a good comparison in terms of being an open, detailed speaker. Any thoughts? I know RS sell Dali's but I'm trying to avoid that route.
Thanks in advance for any input / recommendations / advice you can offer.
