Vladimir said:I can give you and Cno both insulting nicknames if that is the new way of communicating on this forum.
Well that's one less thing to worry about in the New Year.
CnoEvil said:Vladimir said:I can give you and Cno both insulting nicknames if that is the new way of communicating on this forum.
Vladimir said:Now, why a Bryston? Because they can be had under 1K second hand and because they are very speaker impedance ignorant. They simply do the job, they are well made and will last a long time. VFM, check. Power, check. Durability, check. Therefore, why not.
CnoEvil said:in order to do the speakers justice.
	Vladimir said:plastic penguin said:Vladimir said:I vote Bryston.
The Impaler has risen from his box. Why Bryston? (Dreading the answer.)
In his previous thread the OP said he had £2k for amp and speakers.
plastic penguin said:And I'm assuming this comes from personal experience. Right?
Remember I'm speaking from personal experience. As I type now I can glance at my lovely TB2s and Leema Pulse.
drummerman said:max337 said:Thanks both. I should probably halt around about here as I'm yet to demo and am giving myself way too much to do. I need a system now and so hopefully the Cyrus and the PMC combo is good enough to last me until I find some dealers. Then the fun begins.
You may find you are quite happy with the cyrus. It's not exactly a bad amplifier ... .
When Hifi World tested it it came first against some quite interesting products and it can easily partner speakers more expensive than the PMC.
It probably boils down to how loud you listen to your music.
boggit said:As you know i had a Leema and PP is right i dont think he would recomend it so much if it were not a bargin! its a briliant amp at a bargin price at £440 i noticed hardley any differance when i upgraded to a Sugden A21SE. Buy it dont like it sell it for £440 again easy. Having said that i would also like to try the Electro i really like the look, somthing i could not say about the Leema.
steve_1979 said:Vladimir said:Now, why a Bryston? Because they can be had under 1K second hand and because they are very speaker impedance ignorant. They simply do the job, they are well made and will last a long time. VFM, check. Power, check. Durability, check. Therefore, why not.
Bryston are what PMC use so it seems like an obvious option.
MUSICRAFT said:CnoEvil said:in order to do the speakers justice.
Hi CnE
I thought this had almost been forgotten *biggrin*
Anyway, to max337 another Norwegian company Hegel and their H80 DAC/amp is also worth having a listen to
All the best
Rick @ Musicraft
adamrobertshaw said:I demoed PMC twenty.22 with a Cyrus 8 DAC prior to purchase, then ran at home with my 8XPd QX (now rebadged 8 DAC QX), then with Cyrus X Powers. I have been listening since March 2014 with a Cyrus DAC XP Signature and X Powers.
PMC and Cyrus go very well together; whether on a relaxed listen or at high volumes.
Electro said:One of the best things about PMC speakers is that they work very well with a very wide range of amplifiers as long as the amp has a strong power supply and plenty of current delivery .
Electrocompaniet would be my personal choice with Bryston in second place , but Hegel , Leema ,Cyrus and Naim etc will all give a slightly different flavor to the sound so just choose what suits your taste .
The reason I would choose Classic series Electrocompaniet equipment over others is because in the same way PMC speakers work well with any competent amp Electrocompaniet amps work very well with almost any speaker and will drive any load or type of speaker effortlessly with total control.
The combination of Classic Electrocompaniet and PMC will reproduce any type of music equally well and it sounds like real music ( with a natural sounding recording ) rather than just music played on a stereo which is ideal for me but can be a little too 'real' for some people. *smile*
Saying that I have never known or heard of anyone who has listened to any of the classic series Electro amps that has not been more than impressed !
Vladimir said:Bryston, Krell, Electrocompaniet, Adcom, Hafler, Parasound, Threshold. You don't need to poke those dragons with a stick to know they breathe fire.?
There is an AW100 in the local ads that I would like to snag but I promised to buy mom a new stove. Darn holidays. *aggressive*
max337 said:boggit said:As you know i had a Leema and PP is right i dont think he would recomend it so much if it were not a bargin! its a briliant amp at a bargin price at £440 i noticed hardley any differance when i upgraded to a Sugden A21SE. Buy it dont like it sell it for £440 again easy. Having said that i would also like to try the Electro i really like the look, somthing i could not say about the Leema.
I'm also avoiding used gear. I know it limits choice but 🙁
plastic penguin said:max337 said:boggit said:As you know i had a Leema and PP is right i dont think he would recomend it so much if it were not a bargin! its a briliant amp at a bargin price at £440 i noticed hardley any differance when i upgraded to a Sugden A21SE. Buy it dont like it sell it for £440 again easy. Having said that i would also like to try the Electro i really like the look, somthing i could not say about the Leema.
I'm confused. You said many times you want to avoid used gear so why buy a pair of PMCs that were pre-2008. I showed you a lovely pair of Totem Arros (with a returns)...
Not having a go but one minute you want to avoid older gear then you spend on a pair.
max337 said:Electro said:One of the best things about PMC speakers is that they work very well with a very wide range of amplifiers as long as the amp has a strong power supply and plenty of current delivery .
Great. Hoping the speakers make a good base to sample out amps. I do intend to try the Electro amp but maybe the PI effort as I have one local. At least I'll get a taste of it.
drummerman said:Do Abrahamsen have a distributor/dealer network in the UK (or the OP's home country?)
If not I would not recommend purchasing.
Any warranty work will involve a lot of hassle.
plastic penguin said:I think Electros are hideously overpriced now. Two or three years ago when they were £1700, that was good value. But £2400?
plastic penguin said:drummerman said:Do Abrahamsen have a distributor/dealer network in the UK (or the OP's home country?)
Very wise words.
As i said in an earlier post they go for around £440.max337 said:
Its £550. I have a few I'm watching and I need to prioritise. I'm also avoiding used gear. I know it limits choice but 🙁
