Problem with PMC PRODIGY 1
That EQ switch needs to be set to RIAA. You also have that big rotary dial to the right.
Perhaps you need a phono preamp that offers more when it comes to low output MC cartridges, I didn't realise it was that basic.
You would think it would give more flexibility for 800 euros. It's one Whathifi recommendation that doesn't live up to expectations
You will not like this....
"The Bad​
  • The maximum MC gain of 63dB is barely sufficient for very low output MC cartridges of 0.2mV like my Lentek Entre. The additional 6dB provided by the balanced output is not relevant to most systems as many inputs will drop the balanced level by -6dB in order to match other unbalanced inputs.
  • Low end cheap external switched mode power supply (12VDC @ 500mA).
  • The single rail input voltage from the switched mode power supply is converted internally to dual rail using a DC to DC converter – basically another switched mode supply. The good news here is that it is so well designed it creates little to no noise. This one feature almost caused me to not buy this pre-amp as I intensley dislike all forms of switch mode power supplies, particularly when used in low level signal amplifiers. (Linear power supplies rule the roost here)
The Gain​
  • MM Gain – 42dB or x125 – max gain 48dB or x250
  • MC Gain – 57dB or x707 – max gain 63dB or x1414
The MM figure is quiet acceptable, but the MC figure is too low for very low output (0.2mV) MC cartridges – see comments. "
That said your Hana ML outputs slightly more than the reviewers cartridge but this is why you may need to adjust your volume control so much.
Would i be better connecting it to the Vincent ph701, do you think this could be part of the tweeters problem
"The Bad​
The Gain​
I can see a step up transformer on the list ,it's getting expensive 🥲
They have fantastic soundstage and imaging. The best part is they are very musical.
Yes, they drain the volume a little but if your amp has a clean current (your Vincent should have) it won't have an issue. They suit my amp beautifully. As I've not heard a Vincent amp before I couldn't predict how they would interact together.
The Ruicon 2 are purposeful little critters. I love them.
Just make sure you give a 24" from the back wall.
Good luck.
Well they're here,first impressions, wow,large for a bookshelf speaker .
Have set them up 36 cms from back wall with ever so slight toe in.
Beautifully made and love the little cloth as if I haven't enough special ones already ,my Acoustic Energy AE500's have same finish so well versed in the dust issue.
My initial findings were that they were a little non descript initially,but have now run them continuously through the night,and this morning I'm greeted with a different speaker.
Very musical ,excellent soundstage,and very tight bass.
I've got an SVS PB2000 PRO sub with 12inch woofer, but don't really need it on ,though it does go down extremely low when needed.
The mids are very clean and smooth and the highs crisp without being offensive.
My Vincent is a Hybrid and I find the combination very pleasing.
All in all ,am very pleased and look forward to hearing them after further breakin.
Will try them on my old Pioneer Reference amp soon which is a solid state Class A legend in my world .
Think we both have an excellent product 👌
Looks like your Vincent will be better of the phono preamps.
If going down the step up transformer route you could sell the MX Vinyl and possibly the Vincent.
Will try the Vincent and report,selling equipment over here is a non starter, so many scam buyers ,simply wouldn't risk it
Just thought ,I still have my old Arcam r phono, which appears to have excellent gain settings for mc
Spec enclosed
1.Do you think it would be a reasonable option
2. Is it up to the standard of the Hana ml
Spec enclosed
That certainly seems to have ample gain for your Hana and more than the Vincent.
Try it.
No wonder you have so much kit if you cannot sell it.... 🙂
Don't you have dealers that will take trade-ins either?
Thanks Al,huge improvement on the Arcam,hana so much more dynamic,convinced problem resolved. Big lesson learned, going to set up the Musical Fidelity mx vynl with either Ortofon 540mk2 or 2m black,so nothing lost,really grateful for your knowledge, hope this will solve the tweeter problem also as volume levels right down for excellent listening level.
Fitted the 2M Black cartridge on the Musical Fidelity mx vynl, absolutely excellent, volume knob right down and super smooth sound ,another great result 👍
Good to hear.
Although some preamps have an MC facility some are lacking, as you have discovered.
Gain is very important with low output MCs and am sure your Vincent, excellent though it is, could do with a touch more.
Your MX is certainly well set up for MM options but slightly lacking in Gain for most low output MCs.
Best kept for MM cartridges I feel.
Thanks for your thanks by the way, only here to help where I can.
You mentioned that on the night prior to having issues with the PMC's that you had been using; CXN v2 Streamer, Vincent sv-237mkii amp, and SMSL Su9 dac
The next time you listened to the speakers were you still using the same gear/signal chain?
I find it interesting that you were using a $99 speaker switcher with 6 grand worth of gear.
Also curious as to why you don't just connect the CXN v2 directly to the Vincent?
Reactions: gasolin
Picture in #51 he has 2 pair of acoustic energy speakers, kef ls 50 meta ?? and the dalis, i think he needs to switch between the 4 pair of speakers but why he bought one for only $100 i don't know
I think so. I wouldn't change them for anything within their price bracket.
Enjoy!
Enjoy!
Just thought you might be interested in an update after trying them in numerous different configurations. I have finally ended up with them connected to my old Pioneer M73/C73 Reference amp circa 1985,turntable Project debut pro s with Hana ml cartridge and Arcam r phono preamp. Sound sublime,really loosening up now ,the Hana makes the best of them. Just one mod,had to put a sock in the rear ports as in conjunction with my SVS PB2000 PRO subwoofer ,just a little boomy. Can honestly say I prefer them to the PMC prodigy I,your comments about there musicality hits it right on the nail,and so spacious, absolutely fills the room.Have just ordered the stands( In white🤣) glutton for punishment but they are so attractive, need a bit of bling to set them off)
Reactions: plastic penguin
Nice one.
Putting them on dedicated stands might help the LFs. You'll also notice the imaging improves too with quality stands.
My Leema has plenty of punch but not quite as ponderous in the LFs as some price compatible integrateds, so it gives the feeling of a leaner bass... no boom or heaviness to it.
Thanks for the update.
That Pioneer pre/power combo is a classic amp from the golden age of Japanese hi-fi. I'm not surprised it sounds great!
Thanks for your input Matt,it really is a beautiful piece of kit ,had it serviced recently by a vintage hifi specialist, he reckoned it was in as good condition as when I purchased it new back in 91. I would never part with it and it works so well with the Dali speakers and the Hana ML, just purchased the Dali stands in white,love a bit of colour and I think it works well 😀 1000021951.jpg
Nice one.
Thanks for your input Matt,it really is a beautiful piece of kit ,had it serviced recently by a vintage hifi specialist, he reckoned it was in as good condition as when I purchased it new back in 91. I would never part with it and it works so well with the Dali speakers and the Hana ML, just purchased the Dali stands in white,love a bit of colour and I think it works well 😀 View attachment 8245
A fine collection of speakers.
I'm a big fan of vintage Pioneer amps. Interesting they match well with the Dalis.
Good to hear.
Just a final update to the saga,have purchased a Project Step Up S3 transformer, it's now connected to my Clearaudio Concept Turntable with Hana ml cartridge and Musical Fidelity mx vynl preamp and into Vincent sv-237mk amp. Sound is excellent much improved on original set-up. Volume level required now between 2 and 3,that's not 2 or 3 o clock for your contributors who like to criticise before checking,I enclose photo to confirm. Thanks for all your help
Reactions: Messiah
