AKG or Ultrasone Headphones
Jason36
427
Ok I have hit a bit of a crossroad now with decisions on a new set of headphones.....I am torn between either the AKG K271 Mk2 or Ultrasone HFi 780.
I think both of these headphones would be suitable for the sort of music I listen to, which includes Rock (60's to Present), Indie and Female Vocals.
I am looking for a detailed sound....so something that is good with mid ranges...especially for female vocals, decent bass ( however not overpowering).
I believe that both of these headphones meet that criteria...but is one better than the other??
Jason36
427
Well i took the plunge and opted for the AKG K271 MkII as these have had some very good reviews and have been recommended to me as a good choice in the past. Initial impressions are good, although Inwill give them 48hrs before I try and make any critical comments.
However they do seem to be a lot better than the Denon's for stopping sound leakage and this was my main gripe with the Denon's. I also like the neat gadget they have put in the headband, that cuts music to the cups when you remove the headphones :)
Hopefully when they have had 24 - 48 hours to settle down they should be just the job.
Bet you want the Ultrasone HFi 780 still just to compare!
Jason36
427
Yeah probably
But I will wait and see what the review in next months WHF says first.
Jason36
427
One thing I have noticed about the AKG's is that the do need proper independent amplification.
I had a short listen yesterday via my iPad headphone socket, and whilst they worked.....they Definately lacked any dynamics and sounded very flat and boring. Vocals sounded veiled and bass was just none existent. However when listening to the same pice of music via my netbook / Caspian Pre Amp / Xcan it was a totally different story....the sound was dynamic, airy and detailed.
I assume this has something to do with the 55 Ohm impedance the AKG's are rated at.
Paulq
333
13
18,895
Hi Jason
How are you getting on with the K271's a few weeks in? How are they for bass and for listening to rock music? I have heard them described as bright? How would you compare to the SR80i's?
Sorry for all the questions - just been dying to try a set of AKG's for a while but am concerned they may be a tad too bright for rock music.
Paul
Jason36
427
Paulq said:
Hi Jason
Paul
I wouldn't call them bright at all, they have good detail and an airy sound to say they are closed back. I listen to a variety of music including a fair bit of rock....I would say that the 271's are not Bass heavy, but they have bass when it is in the recording. I always use The James Blake song Limit to Your Love to test Bass response......the AKG's are good. I always found my Denon AHD2000's bloated and woolly but the AKG's handle it well.
As a whole I would say that compared to the SR80i the AKG's are a more laid back listen, detailed but not in your face and fatiguing like the Grado's can be. That's why I modded my Grado's to try and counter this a bit.
I'm also waiting for a pair of Beyerdynamic T70p's to be delivered....these are also a closed back 32Ohm headphone and are supposed to be a very neutral headphone.
hope the aboe helps....any other questions give me a shout and I will try to help
Paulq
333
13
18,895
Thanks for that I may just give them a try as they are priced pretty reasonably. I am torn between those and the K272 HD's which are 'supposed' to be a bit more forward in the bass department.
I have pretty much sorted my open back solution with the DT990's which sound awesome through the Graham Slee Novo, whereas the SR80i's sounded terrible (never thought I would say that). I'm after a pair of reasonably priced closed backs but they mustn't be bass anaemic because of the music I listen to.
