advice on closed in floorstanders
chinmaster2011
morning all,
could anyone give me some advice please ? i am looking to purchase some new floorstanding speakers, unfortunately the have to be quite close to the back and side walls on both sides, i have a cyrus 9 pre power mono block combination. my musical tase are across the board and a lot of home cinema.
budget around £3k
thanks in advance
Al ears
Moderator
chinmaster2011@hotmail.co.uk said:
morning all,
budget around £3k
thanks in advance
Welcome to the forum.
That's an awkward position for most speakers to handle without sounding boomy. Can you actually get to audition any recommendations?
I would suggest you look at some that have home cinema layouts in mind like the excellent Quadral Chromium 8, which although rear-ported, has been designed to be used close to the rear wall. HiFi World really rated them. Cost approximately £1800
busb
58
As an owner of the rear-ported Quadral's Al mentions, I respectfully would suggest you look elsewhere. They are absolutely amazing speakers but I wouldn't personally want to run them near walls. I do hear that some Rega models work well under your desired conditions but I've no experience.
There is a type of design that will work against walls & they are so-called open baffle models. They are essentially boxless so need the wall to give any bass. Unfortunately, most of these designs are DIY. Also Google clue speaker.
Al ears
Moderator
I bow to your greater knowledge of the Quadrals. It was just that every review I have seen mentions their ability to work close to walls.
I can see that rear port could make that tricky though. Next to open baffle you have the good old sealed-box type speakers, some of which are good against rear walls.
Squidders
My PMC Twenty.23 speakers are front ported and work well close to my wall. The Twenty.24's are easily in your budget and sound very nice indeed. Maybe worth a listen.
lpv
47
check audio note speakers.. these are designed to be placed in the corners
p_m_brown
56
Check out ATC SCM40s. Amazing speakers and work well close-ish to a wall as they are sealed. I've not heard the with your amp but the monoblocks should have plenty of power.
As with all recommendations, home demo is essential!
ASK THE COMMUNITY
