So I was listening to music late night at low volume, and went to the balcony for a smoke.
And when I returned back, I found the stabilizer's fuse blown, the next in line spike gaurd blown and finally the devialet amp switched off. I really don't know what happened.
So I dismantled the devialet and pulled out its power board. There are two surface mounted fuses on the board that have blown as checked by my multimeter.
Don't want to send it to devialet , as they will replace the entire power board and charge me a bomb. And iam unable to find these slow blow ceramic fuses of 6.3A 250V in my place.
So I was wondering if it is advisable to remove the fuses and solder a straight wire on the power board. And then install two normal replaceable fuses of the same rating on the power cable.
Is this safe
Maybe there is more damage to the devialet than just the power fuses, but I will only know how deep the damage is, after getting these fuses sorted to check if the devialet atleast powersup.
Is this safe
