question1- i guess you need a pre-amp to connect all you stuff like turntable/dac/cd/tuner ect then use the built in amp as a power amp may be wrong it makes sense in my head. so if so could i use my arcam alpha9 as a pre-amp.
question2- say if i like some speakers that are £500 do i need spend x2,x3,x4 the amount to gain the same quailty with active speakers.
question3- do they have a pre-out to add a subwoofer if you wanted
question4 do they need differant stands are can standard stands works.
many thanks simon
many thanks simon
