- Aug 10, 2019
- 2,556
- 5
- 0
I am giving serious consideration to buying the TX-P42G10. I have found one for considerably less than the listed price but will not be able to view it properly before i buy. In the review you wrote
"Up the ante to Blu-ray discs at 1080p/24fps, and the 'G10's command of colour, contrast and detail is even more impressive. Very complex patterns can cause it a moment's anxiety, but it's a very impressive plasma set overall."
Could you clarify exactly what "a moments anxiety" means? and give some examples of the complex patters that might cause it, also is that specific to blu-ray discs? is any particular player likely to cause problems?
Thx
If anybody owns this TV and wants to chip in, feel free
Edit: After a closer look, the TV i am looking at is a TX-P42G10B, is that even the same set ?
Thx
