720p or 1080i
Gazuk
29
Hi everyone,
I have a 42inch Panasonic Plasma TH42PV500, Toshiba HD-E1
Fantastic picture quality with hi-def dvds but which setting should i be using on the dvd player 720p or 1080i??
Also i get juddering when the camera zooms or pans! Is there anything i can do to reduce this?
Any advice would be welcome
Cheers!
With a 42" it's gotta be 1080p surely?
Can the HD-E1 receive firmware upgrades via a broadband connection? If so get the latest update, it might solve your problem.
That TV's only an HD Ready spec, from a generation that I don't think supported 1080p or 24fps. I'd go for 720p over 1080i - good story supporting that view here.
Thanks for the info, it looks like its got to be 720p
I have a 1080p panel, but my V-box is set to 720p. The broadcast pix (especially graphics and diagonal lines) look waaaaay superior.
