I’ve decided to get back into hifi after an absence of many years and have allocated 5k, (6k at a push if it warranted it) but if I can find an amazing system for less that’s fine!
I’m looking for new speakers an amp and as my source a turntable.
My listening room is quite small 4m x 3.5m I do prefer floorstanders but will consider standmounts which produce good bass
I’ve already listened to some Dynaudio X32s and PMC twenty 23s and found them both excellent however compared to the Dynaudios I found the PMCs a liitle harsh and maybe a little fatiguing for longer listening sessions whilst the Dynaudios just seemed to sound right.
I listen to all types of rock from the 60s to modern stuff
On the subject of turntables I was told it’s not worth spending more than £500. Do you get a much better sound quality from a £1000 turntable compared to a £500 one or is it more a question of esoteric designs and better build quality/looks? Same for tonearms do much more expensive ones give a far superior sound?
