37 inch PX70 niggle
It does seem that some people(probably me included) have a small niggle where the Panasonic it concerned. As good as the set is, it still puts people off by only being 720p, for some owners there is still a slight worry that your not seing every drop of detail, so can anyone answer the question : - Can you tell the difference sitting beyond 6 feet away from the screen between this screen and a similar 37 inch FULLHD set?
Somewhat subjective question, but imo, no you can't tell the difference.
Andy Clough
776
[quote user="ken71"]Can you tell the difference sitting beyond 6 feet away from the screen between this screen and a similar 37 inch FULLHD set?[/quote]
Frankly, on a screen that size and at 6 feet, no. The PX70 is a fantastic set, with deep, detailed blacks and natural skintones. Simple advice: don't get hung up on the specs, check out the picture!
Clare Newsome
1,657
In fact chances are that with SD content - ie normal TV - it'll look better than a Full HD set from that distance, as there'll be less upscaling involved....
