If you ever spot Spam (either in the forums, or received via forum direct message) please use the Report button at the bottom of each post to make sure a Moderator can handle it quickly. Thanks for your help in keeping things running smoothly!
The player consumes 13 watts according to the service manual. The number of amps drawn should therefore be 13/240. A 3 amp fuse allows for up to 720 watts. A 3 amp fuse is more than adequate (note that the internal fuse which is what protects the player is 630 milliamps.)
