Hi all,
having recently been bitten by the hi fi bug again i am starting upgrade my old hi fi which i have listened to for the past 18yrs.It all started when my Arcam black box 50 died last winter,which i had been using with a meridean 200 transport.This promted me to switch to pc based source using FLAC files.Firstly i purchased a cheap DAC to get me going this fed a Nad 1000 pre amp which in turn was hooked up to my Quad 606mkll driving a pair MA 14s.I was very suprised at the quality&convenience of the new pc based system however as allways i started to look on ebay for bargains to further improve the sound.The first change was a Beresford TC-7520 which can also be used as a pre&as it turned out this was a good improvement on the nad pre amp.The next purchase was a pair of MA gr10s to replace the MA14s which were bought when i had a bigger listening room so they were never quiet right in a smaller room.I also used these with a Rel Q100 sub&still use the Rel with the GR10s they work very nicely in my room which is 9ft x 14ft so quiet cosy!So far the uprades have worked out very well&i'm enjoing the sound from the new additions.Plenty of detail&open with a good midrange with plenty of controlled low end.But now i'm trying to evaluate the Quad power amp but i'm not sure which way to go.Is it still a good power amp compared with what i could get on ebay say the Arcam p90/A85/p9/10s or the music fedilty amps A3/5.Having not listed to a lot of different systems i'm not exactly sure where the Quad falls in terms of sound i.e lean&nuetral,warmth.Not in any rush just considering my next move any suggestions would be warmly welcomed.I listen to a wide range of music bob dylan,the who through to ub40&dance.
