Hi There i bought a Yamaha and i think there is a issue with it if i run my finger across the top of the front it feels like its been put together incorrectly if i put my finger on the right side it feels if the plastic front it higher than the metal case and if i run my finger along to the left side the panel goes lower to the point where the metal is higher than the Metal casing
is this a Qc issue and should i return the unit ??
