michael.seigal said:
Thanks that's really helpful. My floorstanding front's don't show up until next week so I won't be able to run through the setup until then.
I have already updated the firmware via a wired ethernet connection and had a look at some of the speaker settings. I noticed the large and small options and also - I have my sub but with the 2 seconds I checked it, couldn't get it to work with a test tone, that being said I didn't really bother doing much of the setup because I'm waiting for the other speakers to come!
Michael
if you keep scrolling through the speaker levels list you should come to a section saying subwoofer and it should give you the test tone and there is a section but can’t quite remember of the top of my head but speaker placement were you select or the other were it says 5.1 , 71 or it might be in the same menu where you select speaker size .
I can always check tomorrow to be 100% sure
do not be tempted to select big for your fronts even though they are big floor standing speakers it’s only for full frequency speakers that can be used as big and there are not many speakers that are full frequency speakers so small all a around and setup you sub in the AV menu as you need the subwoofer to takeover the bass duties so in the Av speaker menu you will get to set the crossovers which I’ve left mine at 80hz all around .
if you going to listen to music and use the streaming function , internet radio I would leave the internet lead in then you will not get drop outs when it comes to streaming music though the Yamaha 1070
