bigboss:
I listened to them when I was shopping for my friend. The dealer happened to have a Yamaha RX-V1900, so I was interested in comparing both of them. The 1900 just seemed effortless in performance, whereas I could sense that the 1067 was trying hard. Also, I found that the sound separation was better in the 1900.
But mind you, these differences became apparent only after very careful listening. On normal listening, I struggled to appreciate the difference.
bigboss,
thanks
what is sound separation ?
Also all in all did you feel that the 1900 was sounding better than 1067 ? I mean when you weren't listening carefully could you feel a definative feeling/thought in your mind which said to you that 1900 sounded better than 1067....?
Buddy you are the only guy i've found who has heard both side by side so you can understand how important your feedback will be to me...
[ i'm cant even demo either one where i live, it's only available for order & sale ] i know
I would ask you this in a vey simple way.... Forget all the extra features that the 1067 has over the 1900 or any feature that the 1900 has over the 1067....
If all a AVR did was sound.... just sound....
Which one would you tell me to buy between the two ??
