krish123 said:thanks for the links, the first article suggests that listening directly from the ipod is better than using a dac as would be the case with the airport express. So it seems there is varying reviews putting me in a dilemma :/.
JoelSim said:I'm not sure you are going to get any improvement at all if your tunes are such a low bitrate. I use Spotify Premium (320) streamed through my CDP's DAC and the difference between that and a CD is huge. The CD is way way better, I've done AB tests on quite a few tunes.[/quote
The diference in quality between Spotify premium and red book is not huge, though I have heard differences many times and little or no differences many more.
The issue appears to be the way the signals are handled, if you go out of your way to compare like for like the differences in terms of the music are very small.
For example a flac, ripped to an iPad sounds virtually identical to the Ogg Vorbis file of the same version of the album downloaded and played offline from the iPad's memory, in this case the source and the data handling is exactly the same, only the files are different.
krish123 said:Right ok so the aex may not necessarily improve the sound ?. My other option is to get a dedicated dac. Say a musical fidelity m1 dac or a3 dac. Would this be better than buying the aex ? I'm slightly confused as to the purpose of the aex if it doesn't improve the sound quality.
krish123 said:Just having a think, instead of the airport express would a dedicated DAC be a better option? say something like a musical fidelity m1 dac? will this improve the sound with the ipod connected through it?
krish123 said:thanks for the reply overdose, I think the first logical step would be aex, as at least this would giv me wireless capability if nothing else. my simultaneous step is going to be a new amp, either pm7200 (KI if possible) or one of the new 7000 series e.g. 7001ki.
Overdose said:krish123 said:Just having a think, instead of the airport express would a dedicated DAC be a better option? say something like a musical fidelity m1 dac? will this improve the sound with the ipod connected through it?
Maybe it would improve, but don't expect wonders, a negligible difference is more likely. If you can justify the expense for whatever change you might get, then that's all that matters. In my experience DACs differ very little, others may disagree, but if it were my money, I'd go for the AEX first.
Overdose said:krish123 said:Right ok so the aex may not necessarily improve the sound ?. My other option is to get a dedicated dac. Say a musical fidelity m1 dac or a3 dac. Would this be better than buying the aex ? I'm slightly confused as to the purpose of the aex if it doesn't improve the sound quality.
The AEX is a multi-purpose device. Apart from being the cheapest way to introduce Airplay to a system, it is also a print server and range extender for your network.
It works great straight out of the analogue output (3.5mm socket).
krish123 said:lucky lion, im aware that these amps are not the newest however they are classic amps, and im not sure even the newer budget amps can beat say the pm7200, or maybe im wrong? i wonder how a pm6004 would compare to a pm7200. i dont have the luxury of auditioning amps so thats not an option, anyone here who has heard both?
