Deleted member 2457
I am looking for something to play my music by Bluetooth. Budget around £1000 or lower perhaps higher.
Yep, you are right BB. I have decided to get a 3 metre cable and play my music from my system. I am surprised I hadn't thought of it before!bigboss said:I would suggest you save up all this money intended for soundbar and wireless bluetooth speaker and aim for a good AV receiver with all the bells and whistles including Bluetooth. You can then get some upfiring speakers for Atmos.
Spot on, I have a Bluetooth speaker at around £200 and it does do the job equally as well. Cheers.QuestForThe13thNote said:Something like kef ls50 wireless active speakers does Bluetooth, but double the budget. Then what about a naim muso for £995, which you can add different colour covers. Also does Bluetooth, like a sound bar type speaker and one of the best of that ilk.
but surely speakers of the ilk and quality at that price are good enough you want to stream music either files from a nas or computer, or stream cd quality streams from tidal or qobuz etc? So not sure why you want to do Bluetooth which is a compressed format, so sq won't be as good. Ok maybe if you've got a speaker at £200 to Bluetooth, but at this price I'm sure you will hear a difference. So Bluetooth wouldn't be on my list of priorities.
