swapping to a music streaming amp
i was going to do that but space wise would be better to have a new streaming amp. or the streamer would be in a cupboard below the current amp. not sure if it would affect it being in a cupboard.
Be aware that a streaming amp will be obsolete once streaming services come and go, or change their API's and the amp manufacturer doesn't provide software updates anymore. A pure analogue amp will never be obsolete. Especially if they don't use any proprietary components. When the services change, simply replace the streamer if there are no updates anymore.
Reactions: nopiano
"Streaming amps" usually have a plethora of analogue and/or digital inputs, so no they wont become obsolete.
well, i went into rayleigh hifi to buy some speaker cable and came out with a Wiim ultra. haven't fully used it yet, but seems perfect. sits on top of my amp nicely!
You've done well, perhaps in the near future you may consider a good DAC and use your Ultra as a transport?
TBH, the DAC on the Ultra is already good, you would need to spend considerably more on a DAC to see the improvements. I'm just emphasising, your purchase is future proof and you can grow with it, when it suits you 🙂
Reactions: Juzzie Wuzzie
