swapping to a music streaming amp
ianh21
6
hi
i am considering a new amp to stream internet radio, connect a usb stick with music on and connect my turntable.
i have a Marantz PM6006 UK int amp, project turntable and dali spektor 1 bookshelf speakers.
i have been looking at the Marantx PM7000N or C-612 amp systems. are they good and will meet my needs?
I use amazon music - not unlimited, and dowloaded music. i also want to listen to the wireless in our new library/relax area in our house. i'd also need a headphone socket or wireless bluetooth connections.
Why not keep your existing amp and just add a streamer to do all the bits your amp doesn't do, one of the WiiM range would probably be best if you use Amazon Music and as your amp has a DAC could probably look at something like the WiiM Pro.
i was going to do that but space wise would be better to have a new streaming amp. or the streamer would be in a cupboard below the current amp. not sure if it would affect it being in a cupboard.
No it wouldn't affect it as the commands come from the network, not IR.
If you were to simply add a streamer to your PM6006 and use the amp's internal DAC, a WiiM Mini would do the trick just fine in your system.
I didn't suggest that as OP wants to use a USB for media and not sure if his current amp has that option, the Mini doesn't but I believe the Pro does.
yes, i'll be using USB devices for my music. i don't have a NAS drive anymore. i'll be connecting purely via wifi but im also upgrading my deco system to something more powerful.
I've just double checked and the Pro won't play files from a memory stick, it will however play files stored elsewhere on a network / NAS.
The Ultra is the lowest in their range that plays them from a memory stick, they often have sale on and with Easter round the corner may do then, have seen them at £289.
Reactions: ianh21
Not sure which Decos you have, I tried the BE25's 1st and they were "OK", I also tried an X50 which the speed was quite good but it's WiFi range very limited.
I do like my BE65's though .... I have 3 across the house, the 2nd is set up as an access point and the 3rd as wireless in the most distant part of the house and get 850 down / upload speeds.
Consider also secondhand Primare NP5 streamer transport, tiny box, superior sound than your WiiM, play your music via usb and you can pick up for about £260 on eBay. See link below.
I'm very pleased with mine, I have my streamer transport output to my DAC via coax.
Reactions: ianh21 and Al ears
Tiny little box, you can fit anywhere! 🙂
Dust always shows up on your photos, especially if it is black, can't see it when you actually look at it.
Just adding an extra vote here for WiiM.
I have the Pro and use it for streaming only, connected to a DAC via coax. I get along very well with their app, and it supports a load of services out of the box, plus DLNA/uPNP (a must for me).
I do use wired ethernet, but wifi should generally be ok as long as you don't have competing high bandwidth transfers (like a big download on a computer or a tv stream at the same time).
I was going through my Primare app on my mobile, the seller who sold me the streamer transport hadn't deleted his Tidal or Qubuz account. Mind you, has a nice song collection.
Hi-Res Tidal music is nice 🙂
It's weird when I downloaded the app on my phone, it was able to trace back to the previous settings. My Spotify account is my own but not Tidal and Qubuz.
I suspect it only a matter of time the seller realises this and begins to delete it all, in the meantime, happy days! 😎
Reactions: PieterG
i have deco X50 modem router and 3 x x50 AP's. looking to upgrade.
I'd definitely look at the BE65's then unless you want to spend a lot more going to another brand.
If you don't want the cost of replacing them all at once, do the critical ones 1st as the X50's will work with the others .... or just do the critical ones and use the X50's in the "lesser" needed areas.
very nice mini setup.
i might sound like a dill, but why do i need a DAC, my amp has one built in unless i go for a new all in one unit.
The Primare NP5 streamer is transport only with excellent sound quality. You can use the DAC on your amp. Ideally you'll get better sound from an external DAC, use the coaxial or optical output from your streamer.
Most streamers have DAC built in like your amp, except if it stipulates it's a transport streamer.
In the near future you may wish to upgrade to an external DAC.
There are plenty on the market to suit your budget 😊
Can you "cast" Amazon music to it, it's on eof the things the OP mentioned in the original post.
My bad, I didn't pick that up from OP's original post. NP5 version 1 has Cast services, that should be possible.
Just to add;
I believe NP5 version 2 have more services built in. Second hand Mk2 is about £50 more than Mk1.
I also checked the MK2 specs on Peter Tyson's website, Prisma includes AirPlay 2, Bluetooth®, Roon Ready, and Spotify Connect®, Qobuz, Tidal HiFi and features Chromecast built-in.
Mk1 app version 1.5.1.15 has all of the above, except AirPlay, I can't see Roon either. I'm able to get 192Hz, this should cover all of the hi-res streaming.
You mention the Primare having ‘superior sound’ compared to the WiiM, but if just using both as digital transports should this not mean they will sound identical?
That's what I believed from other's comments, I back to backed a WiiM Ultra and a Bluesound Nano, both using USB out into a DAC and granted it was hard to spot but I did feel there was a small difference in sound.
That's just my eperience.
It's a bit like that old argument all DACs sound the same.
It really comes down to cleaner circuitry, the absence of a DAC, means less electronic noise.
Also, potentially better quality components etc.
I own both the WiiM Pro Plus and Primare NP5, the WiiM is a great VFM streamer no doubt but NP5 sounds more lush, more detailed.
It's a premium streamer transport for a sensible price.
I suspect streamer transports from Matrix and Eversolo will better it in every department but you have to pay guzzions for the privilege.
I love my Matrix mini i-4 Streamer-DAC but NT-1 streamer transport is a real feast for the eyes. Hopefully in a few years I can pick up second hand on eBay, really can't bring myself to cough up £4K. Matrix has cheaper streamer transport brother for the same price as the Eversolo T8, still £1.8K isn't cheap.
I remember spending that much for my daughters first car (2nd hand)!
View: https://youtu.be/RrxfnN5O0JU?si=U0VcB2W5AR88bW0m
