First question has to be what make/model of player and the second question would be you do know you can buy a longer cable don't you ? (discrete wiring will give you a great connection)
If your router is nowhere near your player then you can use homeplugs to connect it to the internet. I have my panny bd80 connected this way and it works fine.
