Myself and my girlfriend use android phones and windows computers, and don't want to change to Apple so sadly cannot use the seemingly wonderful airplay technology.
We live in an apartment, 8m x 5m, and would like to use a single speaker/dock or speaker system to play our music and movies from our phones and laptops, presumably either with an AUX cable or bluetooth, unless you can suggest otherwise.
We tried out the Bose Soundlink II portable speaker at £219 when it was on offer at PC World, and found it below what we wanted (we had listened to the Sonos and thought they are much better, but I later found out that is likely due to the Airplay data transfer being much higher quality than Bluetooth). I am tempted to go out to buy the Bose Sounddock II and use it via AUX, or buy a separate bluetooth adapter to fit on the back of the dock so we can then use it via bluetooth.
Can you please advise us on whether you would recommend that dock for our problem and apartment, or if there is a different speaker system, or set up altogether, that you would recommend?
Thank you for your time!
