white 5 meter rca to rca
gasolin
BANNED
Can anybody recommend me a white fearly thick 4 or 5 meter white cable with small rca to rca plugs?
I know real cabel makes one but at my local shop it's out of stock, it has to be a cable less than 15£ or under 20€
Will make a 5m cable, white Van Damme, decent quality phonos for about £15. That is a single cable though, double for a pair.
I agree with Dave.
Designacable , any length and any colour you like including white with top quality Van Damme cable and Rean plugs.
https://www.designacable.com/audio-visual/rca-phono-interconnects/gold-plated-rca-to-rca-lead-flexible-van-damme-cable.html
Price over 30£ 1x 4 meter cost 13£
I live in denmark so theres no free shipping
I don't know how important cable are when it's interconnects compared to speaker cable.
There somehow has to be a difference when it's an amp to speaker cable or control unit to active speaker cable.
5M is a fairly long for a single ended (standard RCA connector, coaxial shielded audio cable) run.
You should get away with it if you don't run it in parallel with a mains cable, but don't be surprised if you pick up some hum or other noise.
For that sort of length you might want to investigate balanced connections.
Have no hum,noise, i use shielded quality cables
It's just that 3 meters is not long enougth, i don't just want to have it the shortest way, i want to have it long enough so i can use it without having it over or under my pc.
4 meters are okay, but no one makes it in 4 meters, 3 or 5 meters is the standard, unless it's custom made cable and that is not cheap. Over 30$, i can easily get 5 meter of some decent cable for 15£, just not white (theres only a limited white cable in a decent thickness and 4 or 5 meters for 15£) and since i especially wanted genelec's in white (and have it it white) for many years, i don't want to ruin the synergy (if possible) by buying a black cable, but not for 30£.
Kind of funny i didn't thought of that or any of you told me i could just do that
Buy it on amazon https://www.amazon.co.uk/Real-2RCA-1-5M00-Double-Shielded-Cable-white/dp/B00CAPJILU/ref=sr_1_42?srs=3787651031&ie=UTF8&qid=1507986795&sr=8-42
