RCA interconnect over 12 meters for Pro-Ject T2 Super Phono deck to AV amp?
Bluetooth. No. Loss of sound quality.
12m run of cable. No. Same reason.
If this was my room, and if I've understood correctly, then I'd put the TT in the cabinet with the AV stuff, bite the bullet and walk to the TT with a record when you want to change it.
Beautiful looking room, btw!
Reactions: Tange
There are lots of things here, some that have been addressed. The first one is move the record player close to the amp. Or as per my earlier suggestion have a dedicated stereo system. the speaker placement, looks ok for AV but terrible for hifi.
If you are set on your plans, how sure this 12 meter measurement is accurate? The amp loots to be within a meter of the window, the sofa is against the wall, lets call them 2 meters total. If you then run the cable along the length of the window, is that 8-10 meters? Its hard to judge from a photo, but it looks more like six. Move the sofa in line with the window. If you are no longer sitting the TV on the stand, you can play with the position a little. If all these things are true you could be moving closer to an acceptable RCA cable length, around 6 meters.
As far as positioning the turntable in a different place, the side table between the sofa's? The TV stand once the TV is moved?
Finally, have you looked into how you are going to earth the turntable?
Nice looking room BTW.
