Dear fellow forum-members,
Who can offer me some advice on what you would consider the best sub for less than 2500 EUR (~2000 GBP / 3000 USD) at this moment? Here is what I am looking for:
- I listen to 50% music, 50% movies; but music is probably more important to me in terms of quality than movies.
- A clear dream is to reproduce some of the same room lock that a 32-foot organ pipe is able to produce, e.g., in Bach's Toccata in D or the Organ Symphony by Saint Saens. I am assuming producing some seriously low frequencies at decent SPL will be needed to do this
- My room is 5m X 12m X 2.5m, but it is connected through an open hallway to the rest of my house (firstly a second sizable room of 6mX5m); and there is a likelihood that I move in a year to a bigger place, so having a little bit of ability to spare to create room lock might be beneficial
- I am unclear whether I need built-in EQ
- Current system is the NAD c390dd, Sonus Faber Cremona Auditor M, what I am considering a quite musical system. The Sonus Faber already has quite a surprising amount of bass BTW - if not at the lowest frequency ranges (Sonus Faber itself claims down to 50Hz, which I am inclined to believe). The NAD c390dd also has a sub-out, so I am not dependent on speaker-level inputs.
I have been able to listen to Velodyne SPL 12 (now also known as the Velodyne Optimum 12) - it sounded great. But I am wondering what other options are like:
- Dali P10-DSS or the Mentor Subwoofer
- B&W PV1D or the ASW 10cm
- SVS PB13-Ultra
- REL R528-E or perhaps the G2
- Others?
Of course - I know that some of the more expensive subwoofers might very well able to do this, but my budget does not reach that far unfortunately.
Also, having listened to a few subs, I find it harder to make comparisons than with regular speakers, so any pointers what you listen to and how you test a sub's capabilities in practice would be very helpful as well.
Thanks for any ideas that you have to offer!
Paul
- SVS PB13-Ultra
- Others?
Paul
