- Aug 10, 2019
- 2,556
- 5
- 0
Can anyone offer advice on which speakers I should choose from (say 3 or 4 to listen to and check out) to match up with a CA 840A V2. Ideally they should be bookshelf but don't have to be. Budget is circa £800
kevinJ said:I've always found Cambridge Audio gear to be on the bright side. Imo, stay away from Kef, since those are a little bright too. The combination of the two might be too much.
B&W should be on you list to audition, and I guess Dali too. Maybe the RX series of Monitor Audio, but I find them to be very neutral, and the brighter amp might push them over the edge too.
Audio Maniac said:I totally agree with you Kevin. I tried 840A V2 and 740A with KEF XQ20 and the result was bad. Too bright!
Avoid neutral and bright loudspeakers. I read some reviews describing the referred amps like neutral but believe me they are not. They are on the bright side for sure. So, they need warm loudspeakers and sources to sound fine.
