Which Speakers should I choose for my new Home Cinema?
I am going to upgrade my home Cinema with the following equipment, however I struggling with the speakers.
  • Pioneer 508XD wall mounted with undermount speaker
  • Pioneer LX50 AV Receiver
  • Pioneer LX70 Blueray player
  • Possibly a Sunfire D8 subwoofer
I want the speakers to be mounted on the wall, I have about £1,000 for the front, right, centre, and surround speakers.
My room is 17 foot wide by 12 foot deep
Any advice greatly appreciated.
Regards,
Chris
Be sure to put this on your audition list - WhatHifi Award winner the Monitor Audio Radius90 AV-12 system (could go for less than £1350 without the sub)
The black piano gloss will match your receiver, and its small enough you wont have to worry about the weight if they are wall mounted
Thanks very much, have looked at Monitor Audio and I going to go a head with r250's for the LCR and R90's for rear RL. Changing Sunfire D8 for the Monitor Audio sub.
