which speakers for Sony STRDA2400ES
Hi bobbys,
Out of your list I would look into the kef 2005.3.
Friend has the original version of those speakers, and they are very, very good.
I don't know if this will help you but i have the older 2005.1 and I love them. Everyone that has heard them find them just outstanding. I am about to update my system and am looking at only two sets of style speakers and thats the 2005.3 or the 3005se. I have also placed 4 sets of the 2005.2 into friends/family homes. So as it looks the new set 2005.3 are going to be out of this world.
Try to locate a set of Sony SAVE835s, also known as Pascals. They are now discontinued but are absolutely incredible for the money. Not an obvious choice but then the best ones often aren't.
I have the Jamo A102 5.1 set connected to my DA2400ES.
They sound fantastic. The SUB is very beefy 200W box. They look good. They cost about 200 quid. Available in Black (piano gloss), White, or silver.
Boo
thanks all
Boo, what size room do you have? and do they sound really good and do you think that the sony is to good for them?
also what cable you using for the jamo?
thing is i like the keffs because there keffs and a good design but i like the petite jamo's because, well there petite. And at £500 cheaper it should be a no brainer.
thanks for your time
