Which CD player????????
sumit.india
8
This is Sumit from INDIA.
I am having CAMBRIDGE AUDIO AZUR 650A as amplifier.
I have choosen CAMBRIDGE AUDIO 650C as CD player and MARANTZ CD6004.
Which ONE should I buy???
Please advice.....
I have listene to both an for me the ca was better. Sounding a ltle more detailed an a litle less atificial.
Some would say it can sound a litle bright but I doubt this will be the case with your amp.
For tha rest Its more a question of taste. an If I remember well the Marantez was also a little cheaper.
Good luck
The one you like the sound of best! They're both very good, it's down to your personal taste. If it were me, I would choose the CA simply because it matches the amp and can be controlled with the same remote!
Thanks a ton to Whiskywheels & Roby.
I will certainly go for CA...
In India, the price is almost the same.
But right now CA651 is available.
What is the basic difference between CA 650C & CA 651C.
Please help.... :help:
Please advice.....
Suprabhata Sumit
What genre of music do you listen to?
Your interconnect, speaker cables and speakers are?
Your maximum budget?
What kind of presentation are you looking for the system to reproduce?
Bada mem
Rick @ Musicraft
Hi!
Rick,
The details are as follos:- Jazz, Blues, Rock, Alternative...... That's my choice.
Amplifier is :- Cambridge Audio Azur 650A.
Interconnect :- QED Audio Performance 2.
Speaker Cable :- Norstone Classic.
Speaker Tower :- Wharfedale Vardus 300.
I require a balanced performance....The Mid, High and Low should be in level
go for Maratnz C6004! I'm having a Marantz C6003 (partenered with NAD C355) and it sounds excellent!!!
however, duo azur 650 a+c also a great combo, hard to beat in terms of sound-stage....and you can use only one remote-control....but, you have to try and test which combo pair the best with your speakers and cables etc......
The details are as follows:- Jazz, Blues, Rock, Alternative...... That's my choice.
Please leave your comment in the terms of the SOUND QUALITY rather than the remote convenience.......
Please help me to take the right decission.... :boohoo:
For what it is worth have you considered a music streamer as a source instead of a CDP, using your MAC or PC as a music server? CD is on borrowed time in my opinion. A dead medium before the decade is out.....
a onkyo c7070 a very nice cd player with very high specs for the price
sumit.india said:
Hi!
Rick,
Nam ask ara Sumit
Thanks for your reply.
I would recommend the CD6004 as its overall fuller and fluid presentation should work well with your amp and speakers.
Sabhi behatarina
Rick @ Musicraft
MUSICRAFT said:
sumit.india said:
Hi!
Rick,
Nam ask ara Sumit
Sabhi behatarina
Rick @ Musicraft
I owned the ca 640c v2, great detail but after awhile I found it a bit bright for my tastes and on some music like jazz I found i became fatigued after 30minutes listening, so I sold it, great for rock and pop though.
I also own a marantz and have listened to the 6003 they tend to be a little more balanced tonally, and a little more natural and fluid in the mids, and generally are good allrounders with various types of music.
Hope that helps.
Steve.
