WHF review Audioquest FLX-SLiP 14/4
Hi all, In the WHF review the Audioquest came very favourably against the other budget speaker cables and looks to have all the attributes I am looking for. Having looked at the speaker cable and the title (14/4) this cable looks to have 4 conductors as opposed to the usual two. Can the guys at WHF please confirm that it was the 14/4 that was tested, and was it tested in a Bi-Wire configuration.
Many thanks
Judging from the image it looks like it was terminated into two plugs, probably combining the two positive and two negative conductors I imagine. AudioQuest do also make a two conductor version of the FLX-SLiP.
Excuse me, so is it true or not? :) Does it make sense to make 2 terminations from 4 conductors? Will it improve sound? Do you have instructions how to terminate 14/4 with 2 plugs? Thanks!
I am in the same boat....
Want to try it.
But for single wire is better the 14/4 connection 2 by 2 or the 14/2?
Will the 14/4 sound better 2 by 2 than using it as bi wire one plug to each strain?
help please:D
this:) any thought?
peterpan
160
A good cable, but i find the Wireworld Luna 6 speaercable better. More full bodied sound and sweet voices. Never shrill. Why not the Luna 6 speakercable of the year?
ellisdj
377
Wiring it 2-2 but using 4 runs is basically biwiring
I think that is likely the main attributor to it being the better cable - I reckon that gives it the edge in clarity that they say it has over the others
Not heard just commenting
I do know of an amazing Speaker Cable that has just come out - its far more expensive that this but its quite exceptional for the money.
More on this coming soon when I have the time
Sorry, but can I check if the Audioquest FLX-SLiP 14/4 is effectively bi-wired or not, when using in a 2-2 configuration?
The reason I ask is that I'm keen on the MA BX2s, and WHF forbids me from bi-wiring them, yet the AQ cable sounds perfect.
Muchos gracias.
