When I turn my TV on my Blu-Ray player comes on at the same time!
  • Start date
Deleted member 2457
Does anyone know how I can solve this? Ta
Also when I turn my amp on it automatically goes to muting, any ideas? Cheers.
chrisr1718
52
Sounds like it's something to do with the HDMI control. This will turn off/on devices that are connected via HDMI. There should be something in the settings where you can disable this feature.
Deleted member 2457
Cheers. I have gone into the settings on the TV and then HDMI auto setting and it just says all HDMI inputs are on Mode 2. Any ideas.
richardw42
299
There will be a setting somewhere on your tv that will be called CEC or similar. If your bdp comes on, then you should set this to off.
Pill see if there's a Wikipedia page and post it.
Deleted member 2457
chrisr1718 said:
Also, chedck the VIERA link settings.
Yes, I have this one. Viera link is on, power on link is on. Power of link is on, the rest are off. Which one then? Ta
Deleted member 2457
Couldnt find it.
Deleted member 2457
Okay, I turned Viera link off and that seems to of worked. Cheers. What about the amp? Hang on it seems to have solved the amp too! Brilliant - cheers!
Deleted member 2457
chrisr1718 said:
I'd go for turning them all off but I would start with the 'power on' link, seems the most obvious, turn that to off.
Cheers for the help guys.
nugget2014
215
Sometimes when I went on Netflix my blu ray player would come on didn't know how to stop so unplugged it! Old TV had a problem too with it. Annoying..
Deleted member 2457
Yep.
Deleted member 2457
spiny norman said:
chrisr1718 said:
You could always look in the instruction manual .
If gel ever decided to RTFM, that would double the time of ownership before he moved on to the next purchase. ;-)
Hopefully this one is a keeper.
