What to buy next: Amp then Sub...
I am about to move house and want to upgrade a few bits and add a subwoofer. Given that Blu-ray won over HD-DVD, I will shortly get a Blu-ray player but will make do with the PS3 for now. What I am looking to change first is the surround Amp. I am also looking to simplify my system from a set up perspective so that I get decent video switching (choice of 2x HDMI outs needed). I have moved slowly from an all music system to a Movie system, hence the mix of stuff below. Music is still important to us, so the Amp needs to be good at that as well. I have looked at the Onkyo ones but am concerned that the music side of things will let me down. I have a couple of hundred DVD's so upscaling would be nice.
Next few purchases are going to be (in this order)
- New surround amp (£1500 max)
- Sub (£1000 max)
- Add extra rear/side speakers
Also on the list:
- Consider new fronts
- Match new centre to new fronts
- HD PJ will also be added at some point
- Good Blu-ray player when happy with the offerings.
Can anyone please help me plan this set up? We move house in a couple of months so it will all be fitted in a nice new pad, and I will then consider getting it properly calibrated. What Amp / Sub / Speakers?
I am currently running the following set up:
Displays:
Sim2 Domino 35
Pioneer PDP428XD 42"
Speakers:
Front Centre Linn Centrik
Fronts Linn Keilidhs
Rears M&K K4 tripoles
Sources:
Pioneer DV989
Sony PS3
Virgin Cable Hi-Def
Amps
Pioneer AX5 driving centre and rears
Fronts Bi-Amped through Linn LK140's
As for subs around £1000. Personally, if I had the room and I'm guessing with your set up, you have a fairly decent sized room, I would connect two Veoldyne Microvees. I'm sure if you went to a dealer and said you wanted two, they would do it for £1000 or a bit under.
Thanks very much.
Anyone got any ideas what to put the Denon 4308 up against when I test them?
And having just moved to North Kent, any recommendations of good retailers who will fit the kit?
Receiver: Onkyo TX-NR905, 4 HDMI inputs & 2 HDMI outputs. Great sound too. In budget at £1400.
If looks are remotely important, you've gotta check out the PV1.....I have one and despite differing opinions on here I love it. I haven't had a high end sub before, but I honestly can't think of anyhting else it could bring to the table. People complain it doesn't do sub bass (Bit confusing that, because that's its job?!?!). I watched Saving Private Ryan, the explosions during the first 20 minutes of the Omaha beach landings sounded and felt like I was being shelled in my living room......MUCH LOW BASS!! Although 2 smaller subs for the same price would undoubtedly sound excellent too. For your surround speakers, take a look at B&Ws XT range, not cheap, but looks to die for and been reviewed favourably also.
[quote user="Dak"]Anyone got any ideas what to put the Denon 4308 up against when I test them?[/quote]
You're looking at the Onkyo TX-NR905, the Marantz SR8002, the Pioneer VSX-LX70 and the Yamaha RX-V3800 I reckon as the main competition (Yamaha and Pioneer only have one HDMI out, though you could always get an HDMI switch box with two outputs to correct this).
Thanks guys. I have a listening set up for this weekend on the Denon and the Onkyo.
After hearing some friends I do like the sound of B&W but I think the XT's may be a little too modern for my taste. I was trying to work out where I can get into the B&W range cost wise but that is a little confusing at the moment. I like floorstanders and so will stick with those. The 8xx series comes out a tad expensive though and the others all seem to be changing. I will have to find a stockist with the lot in and start with the rears then add to them.
[quote user="Dak"]Thanks guys. I have a listening set up for this weekend on the Denon and the Onkyo.
After hearing some friends I do like the sound of B&W but I think the XT's may be a little too modern for my taste. I was trying to work out where I can get into the B&W range cost wise but that is a little confusing at the moment. I like floorstanders and so will stick with those. The 8xx series comes out a tad expensive though and the others all seem to be changing. I will have to find a stockist with the lot in and start with the rears then add to them.[/quote]
The 600 range is virtually brand new. Probably won't be updated for a few years yet. Check 'em out.
Well, I had a long Saturday morning listening to various set ups and gear. I listened to the Onkyo TX-NR905, the Marantz SR8002, the Pioneer VSX-LX70 and the Denon 4308. Source was a Panasonic Blu-ray for all. The Yamaha RX-V3800 wasn't stocked here.The Pio sounded nice, similar to what I have but it didn't blow me away, especially with music. It was competent but not exciting.The Onk was great with action moves but I thought lost the subtleties of quieter 'more atmospheric movies' and music. The Denon I really couldn't fathom if I liked or not. I wasn't quite convinced with music (classical and a bit of jazz) but with the Bond BD it was great in the action bits and quiet in the dialogue sections. It may have been the set up?The Marantz I think I liked, but it was booked into another listening room so I only had about ten minutes with it. The salesman thinks that I need to up the ante in price and look at the items in the £3000 range and said that the Marantz was good but didn't have THX Ultra 2 (not sure I need that as I didn't know what it was) or video upscaling. I am reluctant to go to £3000+ unless it is a major step up in quality and whilst I can afford it, the more I spend the longer it will be before I can upgrade the Sim2 Domino 35 to an HD PJ. I have spoken to a number of people who think I must be mad to consider anything other than the Onk but I wasn't blown away.I was concerned that in my home room (26ft x 17ft) things may all sound different again and (again aesthetically - plus a little nod towards the missus - I usually get a source from the same manufacturer as the AV Rec I am using).I listened through the B&W 6xx series which I thought sounded great with all the amps, but I still (aesthetically) prefer floorstanders at the front, and the salesman was raving about B&W's rears that are di-poles (or was it tri-poles) but they didn't have any of those in. Subwise, well to be honest we tried about ten but I couldn't get past the B&W PV1 as I just love the look of it. I am concerned that this is colouring (you know what I mean) my hearing though.So I came away:- without any real decision on the A/V receiver
- have decided to try and hear more of the B&W range- bought a PS3 on Monday as a stand by Blu-ray (I will get a Blu-ray player later but it makes no sense to buy DVDs now so I am buying BD's and needed something to play them on).
My confusion continues!
You could get 683s for the fronts, 686s for surround plus the 6** centre (Don't know the model number). With regards the PV1. As I said before, I have one and I think it's great. I honestly can't think of anything it doesn't do when it should, or vice versa. Only issue I do have with it is that I leave it on auto (Turns on when it senses a signal) and it cuts in and out when the bass frequencies drop out or come in, but I could leave it on 'On' full-time. It's not that big of a problem to be honest.
[quote user="Dak"]Well, I had a long Saturday morning listening to various set ups and gear. I listened to the Onkyo TX-NR905, the Marantz SR8002, the Pioneer VSX-LX70 and the Denon 4308. Source was a Panasonic Blu-ray for all. The Yamaha RX-V3800 wasn't stocked here.
So I came away:
My confusion continues![/quote] I like that you weren't forced into getting a receiver as you weren't impressed (you are hard to impress!). I would wait for a month or so as the new Denons and new Pioneers are out then. Maybe they will float your boat. As for subs, did you try the MA RSW12 by any chance? I am totally blown away by mine and would be interested in another opinion.
why dont you spend £100 on the onkyo or simular then spend £500-600 on decent stereo amp and use with pre-outs, this should give you the best of both worlds.
Well, I can advise you from my purchase a few years back - eventually I spent £2,000 on the Denon AVC-A1SE amp just because it blew me away whereas most of the other amps didn't. From the sound of it, you're thinking of compromising due to the cost, but I would definitely advise against that. Audition the dealer's recommendations, just remember to keep your sensible head on. I would hope the dealer doesn't try and and point things out when you're listening (mine didn't which is one reason he got the sale!) as you definitely sound like you know what you want. If the more expensive system gives you the feeling you're looking for (and you'll know when you hear it), that's when you've found your system.
But get a proper session with the Marantz you liked and see what you think first, then listen to the receivers which are a step up in price. I've seen some reviews of Denon and Yamaha's high end AV amps and they look sublime. They may cost an extra £1,000, and yes, that may mean it'll be longer till you upgrade your projector, but if they provide that truly mesmerising sound you're after, at least you won't be sitting looking at your new projector thinking, "I wish I'd looked at those more expensive amps"....
No, they were not an MA stockist. What about moving up to the B&W 7xx series? Affordable, but is it worth it?
As a side note, why can't I paragraph my posts? I have paragraphs in when drafting, but when I hit post they don't appear....
[quote user="matt444_2000"]
[/quote]
I have the Linn Majik and two LK140's which run my current fronts (Linn Keilidhs) but I want to move to a simpler system (read less boxes = happier wife).
And thanks Gerr, I have tidied my post reporting on Saturday to make it more legible..
[quote user="Dak"]No, they were not an MA stockist. What about moving up to the B&W 7xx series? Affordable, but is it worth it?
As a side note, why can't I paragraph my posts? I have paragraphs in when drafting, but when I hit post they don't appear....[/quote] Try if you can to demo the RSW12 then. I can't imagine anyone not being impressed. In fact while you are there, you could check out the speakers - silver and golds. The new Denon receivers mentioned on this site a few days ago are expecting better stereo sound so I would definitely worth waiting for.
Ok I tried an MA speaker set up at the weekend. It sounded very good.
What do you guys think is best in order of purchase though? Should I decide between the B&W or the MA and get an AV Amp in a month or so? Or should I decide on the AV Amp first and then get speakers?
I am sort of thinking that different AV Amps will sound different with different speakers, but do not know which to prioritise....
[quote user="Dak"]Ok I tried an MA speaker set up at the weekend. It sounded very good.
I am sort of thinking that different AV Amps will sound different with different speakers, but do not know which to prioritise....[/quote] I would pick your speakers first and then get them running in so they sound good before picking your receiver. You could then possibly home demo - easier doing a home demo with one box rather than lots of speakers!
Thanks for the recommendations - was surprised to see that my question made the last hard copy of the magazine too!
I am currently home trialling the Onkyo TX-NR905 and the Marantz SR8002.
I am thinking of moving the goalposts though. The property market has dived and this has saved me rather a lot on the new house: Hurrah, I have more cash to spend on home cinema!!
So if I was looking to spend up to £2500 to £3000 on the AV receiver, would anyone recommend anything different?
Speaker wise I am now pretty settled on a B&W set up (but interested in your thoughts). I am just not sure whether to go for the 6xx series, the 7xx series or the 8xx series. I am trending towards the B&W 804S as fronts but not sure what to put with them for rears and centres.
Dak:Thanks for the recommendations - was surprised to see that my question made the last hard copy of the magazine too!
I don't think there is a suitable receiver in that price range - the new Denon AVC-A1HD is mid £3k. I would love to listen to the Denon 4308. I think the only reason it got 4 stars from this mag was that it costs a lot more than the others near it but I think it has the edge on paper.
