What is the cheapest media player?
CaptainKirk
26
What is a good reasonably priced media player that is compatible with a Sony Bravia HD TV?
It should be able to handle MKVs and - if possible - .rmvb, wmv etc files as well as AVIs ofcourse.
Internet connectivity would be good too. Thanks.
richardw42
299
I've just ordered a Sony SMP-N100 for 87.99 from Amazont.
It does what I want (iplayer etc) and has wireless connection.
You will have to check it does what you want in terms of compatiblity of file types, but or for not much more, a Sony S370 blu Ray.
naughty573
12
the biggest problem with the sony BDP-S370 as a media player is that it only recognises FAT32 hard drives hence the biggest file size it will be able to play is around 4 gigs - the newer Sony BDP-S380 also recognises NTFS - so if you have 20 gig+ sized files stored for movies then it will play those as well
i have tried a few stand-alone media players from Transcend and Apacer and the one im currently really happy with because it passes through DTS-HD(ma) while playing mkv files is the Mede8er MED500x - i will also be getting an AC Ryan FLUXX when it is available because the FLUXX handles more formats - but it isnt cheap ..... comparatively cheap combined with functional features will be the AC Ryan Playon HD2 or the mede8er MED400x mini
