what is the best marantz cd player when you put cost and what you get for the money in to the loop cd63 63semk2 63ki sig ?????????
my system is
krell kav500i + kef reference 2.2 + marantz cd63se + Chord Chameleon +Chord Epic
i would like to know if there is a better marantz cd for my stereo and my music
dance/drum and bass/ old school
regards
Yes. Much better and your other equipment demands it arguably. Not necessarily Marantz alone either!
However, the new £700 SA8003 gets an excellent review in this month's Hi FI Choice and this is effectively the KI-Signature version albeit not titled as such with the KI moniker. There won't be a lower priced "standard" 8003, but another player around the £300-£350 mark to replace the current standard SA7001.
I just picked up the superb SA7001 KI-Signature player for £300 - that's better than half price - from Hughes Electrical in East Anglia. Partner it with a good cable for bass, the Chord you have might work, but failing that something like a copper core DNM or a used Nordost would do the trick. Without it, the SA7001 is a little lean. Beefs up well though.
Other than that, depending on your budget, you could look at the Exposure 2010s (£600) or the earlier 2010, both of which are boisterous little oiks and the new Cyrus players which are the "ones to beat" (it says) at £800 and £1100.
I'd shop around, get the reviews off the mags and sites like Audiogon or AudioEnz, Stereophile etc and see what you end up shortlisting.
Happy hunting!
