Clare Newsome:
Full-time projector user reporting in
Lens shift can deal with basic up/down left/right positioning, but not cope with common domestic situations where you have to put a projector in a less than optimal position (on a coffee table, say, or, conversely mounted higher than your screen).
Yes, keystone correction is a compromise, but it's only a last-minute tweak to get your picture right where you need it; site your projector in the perfect place and you'll hardly need it (if at all).
I understand, but I took ages to set-up my projector properly so that I didn't have to use the keystone feature, which was worth the effort so that I didn't have to compromise on the picture. My Lens shift on my projector is pretty good, I used mine on a table first of all with the lens shift in tow which was OK, then I mounted it for optimum effect
I just think that looking into a projector with a Lens Shift should of been mentioned and that if you were to use a Keystone the picture would be compromised especially HD. So if it had to be used, it should be because you have no choice and are restricted in setting up the projector
Come on Claire being a Projector user, you know using keystone is a big no no, especially if you have just spent hundreds or a couple of thousands on one!!! And your not getting the best from it
