On my (and Most) AV Receivers there is the room EQ section which I beleive is 9 Band, 63 Hz being the lowest frequency which can be altered. When I perform the room EQ in MCCAC (pioneer) the 63Hz is lowered by around 4dB.
My question is in terms of the EQ curve, if their was a graph showing the entire frequency response of the speaker (my L+R go down to 28Hz) would the response level off again to 0db in the 30s and 40s Hz or would the cut at 63Hz mean everything below that frequncy will also be cut by 4dB ??
