mond said:If you do decide to change the amp, then there is one of these for sale on a well known auction site at the moment within your budget (just)
Class A with some valves; that should warm things up a bit.
it should be ok it says on the Yamaha website that it will do 105 watts in 4 ohm load which is what the Dali Zensor 5 which are a 4ohm speaker and 80 Watts in 8 ohmsGonepostal said:Thanks for the suggestions. Thinking might look into the Yamaha Rn602 even though it's built like a tank.
plastic penguin said:The problem is finding that right balance. If you go too warm you lose out on other aspects, such as transparency, imaging... the same if you go too bright or lively, you tend to lose intimacy, emotion (call it what you will).
For example, the older Nad integrated amps such as the 352 you can cook an egg on the speaker cables. TBH, presentation-wise, they lose transparency... as dull as ditch water unless you have cloying speakers to rein back the warmth.
The OP needs to match a system that suits room acoustics. In turn, that should sound more agreeable.
QuestForThe13thNote said:The Dali zensor Little floorstander actives at the indulgence show were really nice and balanced. Smooth and no treble harshness. But passives could be different I accept.
I've liked just about every Dali speaker I've heard and owned a few (exception being Zensor 1).QuestForThe13thNote said:ive Never really liked Dali, as I think the cheaper ones are quite forceful and the more expensive ones not as refined as some speakers of different makes. But you can often never apply a rule accross a brand, as there will always be one which sounds decent and stands out.
Isnt a powered passive the same as an active? I know one of them doesn’t have amplification.
sorry but I think your wrong Dali speakers can be good with the right amplifier hooked up to them some of the cheapest models can come across a little bight or forward but some people might like this about a speaker .QuestForThe13thNote said:ive Never really liked Dali, as I think the cheaper ones are quite forceful and the more expensive ones not as refined as some speakers of different makes. But you can often never apply a rule accross a brand, as there will always be one which sounds decent and stands out.
I could listen to Dali and Arcam alday and never get bored.Blacksabbath25 said:sorry but I think your wrong Dali speakers can be good with the right amplifier hooked up to them some of the cheapest models can come across a little bight or forward but some people might like this about a speaker .QuestForThe13thNote said:ive Never really liked Dali, as I think the cheaper ones are quite forceful and the more expensive ones not as refined as some speakers of different makes. But you can often never apply a rule accross a brand, as there will always be one which sounds decent and stands out.
ive owned Dali zensor 3s , Dali opticon 6s And now Dali opticon 8s none of theses speakers are bright but they can be with the wrong amplifier as I changed 2 amplifiers that year in trying to get a sonic match with Dali opticon 6s because I knew I could get more out of the speakers because I believe in working with the speakers and I was right because 6 months later I brought the opticon 8s which are a step up on the Dali opticon 6s because the Dali opticon 8s use a bigger cabinet to move more air and bigger bass drivers and I knew they were worth the investment but my Dali opticon 8s are smooth and very refined , detailed , excellent low end bass , good midrange , clean sounding speakers but put them with the wrong amplifier then I understand why you think as you do about Dali speakers .
I’ve heard the Tannoy’s the opticon 6 And 8 out class them easily the Tannoys are not as clear as the Dali’s areQuestForThe13thNote said:The Dali Opticon 6 was never one known for being refined, and if you compared it to say the Tannoy xt6f or xt8f totally different on refinement stakes. Speakers like the Opticon 8 are competing with floorstanders from brands like pmc, spendor, atc, and neat, all British brands which consistently outclass Dali imho. Dali can be a clean sounding speaker but the control of bass of something like a pro ac dt8 around same money, is better. Not as balanced with Dali on bass and treble intergration, and you notice control of bass is not quite up there and dynamically too.
the Dali's have great warmth in the midrange and large warm bottom end more so than the tannoy. What Dali's have you heard ?QuestForThe13thNote said:I agree you get used to what you have had but on the original poster question, this Dali sound is not warm like those tannoys you refer to or the pro acs I mention, or pmcs etc. The Dalis are probably tuned to impress everyone on detail in the dealer showroom with a hike in high frequencies, like lots of monitor audios. But the control of bass comes from the speaker and amplifier together. Something like a pmc twenty 23 or spendor a6r would be a better balance for bass and treble than your Dalis imo. Just more musical. So it’s a preference thing for these areas. I’d have the tannoys over the 6 spec Dali as it suits this taste. What makes a speaker and amp combo really good is the way it can mesh detail and warmth together and is fast and dynamic.
seemorebtts said:the Dali's have great warmth in the midrange and large warm bottom end more so than the tannoy. What Dali's have you heard ?QuestForThe13thNote said:I agree you get used to what you have had but on the original poster question, this Dali sound is not warm like those tannoys you refer to or the pro acs I mention, or pmcs etc. The Dalis are probably tuned to impress everyone on detail in the dealer showroom with a hike in high frequencies, like lots of monitor audios. But the control of bass comes from the speaker and amplifier together. Something like a pmc twenty 23 or spendor a6r would be a better balance for bass and treble than your Dalis imo. Just more musical. So it’s a preference thing for these areas. I’d have the tannoys over the 6 spec Dali as it suits this taste. What makes a speaker and amp combo really good is the way it can mesh detail and warmth together and is fast and dynamic.
