Wall mounting AE V2 Centre - One or 2 Vogels mounts needed?
Pikman
24
I am about to mount my V2 Centre on the wall (brick). I have a pair of Vogels VBL200 mounts and I'm not sure if I really to use need both mounts or if I can get away with just the one. I am worried it might fall off sideways with just one but it looks to be relatively well contructed, anyone got any experience with this?
The weight is OK. Rated to 20KG each and the speaker is 9.
Jammoe
23
Would probably be ok. As long as no-one knocks into it(!)
I'd be inclined to put a couple of bits of blu tak at the front and back just to be on the safe side. The arm of those stands isn't particularly wide.
